OwenK
Apr 22, 2022Aspirant
RBS50 Satellite - UnSecure Connection but fine on Main Router
RBR50 router with RBS50 Satellite Satellite is wired connection Router Firmware Version V2.7.3.22 - on both Auto update is selected, no idea when it updated Everything worked fine until a w...
- Apr 22, 2022
Hello OwenK,
I understand that you are having issues with the firmware version 2.7.3.22. The current RBK50 system firmware version is 2.7.4.24.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#RBR50%20(Orbi%20Router)%20Firmware%20Version%202.7.4.24
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/000037217/How-do-I-check-and-manually-upgrade-the-firmware-on-my-Orbi-satellite
Please let me know if you are still having issues accessing those sites after upgrading!!
Best,
Kevin
Community Team
rvonzenet
Apr 29, 2022Aspirant
hi
i’ve the same problem. my iphone doesn’t connect to the rbs50 and there is no problem to connect to the router. i.ve upgraded with the last version but the problem is still remaining
