Fastrac
Mar 08, 2021Aspirant
RBS50 satellite Connected Devices - Device names - Unknown in web browser
Can someone please tell me how to fix this problem. I've had an RBK50 system for several years which has updated the firmware successfully up to and including version 2.3.5.30. After each update...
CrimpOn
Mar 23, 2021Guru - Experienced User
Fastrac wrote:
Is the only option to roll back the firmware to 2.3.5.30 which is the last version where the names were correctly displayed ?If I have to roll back the firmware, how can I stop it updating to a later version ?
I observe the same thing:
- Attached Devices on the Orbi router correctly displays the name, model, "type", and cute picture.
- Connected Devices (not "Attached") on the RBS50 and RBS40V display "unknown", with the exception of two entries on the RBS40V that do not match the router.
This definitely is related to firmware, since version 2.3.5.0 works correctly and more recent versions do not. The choice appears to be (a) stay on 2.3.5.0, or (b) stop looking at Connected Devices on the satellite.
The user has no mechanism to stop firmware from updating.
Have you actually experienced the Orbi updating firmware without any action on your part?
Fastrac
Mar 23, 2021Aspirant
Thanks for your reply.
Going back quite a while I would get a notification of new firmware available when I logged into the Orbi and had to click on the notification to install it.
Recently I have seen some posts in other peoples threads about theirs being updated automatically overnight.
I don;t want to roll back to 2.3.5.30 and set everthing up again, then Negear automatically update it to a newer/problematic version 'overnight'.
Many things come and go on my Orbi and I like to keep track of whats connected to ensure only what should be on the system is connected.
Having working device names makes this much easier that looking at IP addresses.
- vajimMar 23, 2021Master
Fastrac wrote:Thanks for your reply.
I read ..."had to click on the notification to install it." Not auto push
I read..."Recently I have seen some posts in other peoples threads about theirs being updated automatically overnight......I've not see this in years....Not even sure NG does this anymore
- FURRYe38Mar 23, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update? Sometimes it takes the system time to settle in and take account of the devices and populate them...- vajimMar 23, 2021Master
FURRYe38 wrote:
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update? Sometimes it takes the system time to settle in and take account of the devices and populate them...does not work
Worked for me.
