boxersoft
Aug 10, 2024Aspirant
RBS50 Satellite constantly flashing white
I've got an Orbi RBR50 router with two satellites, one connected to the router by 5G wireless and the other by ethernet cable. It's worked satisfactorily for the 4+ years I've had it but I recently n...
boxersoft
Sep 27, 2024Aspirant
Thanks, I'll try to give the generate button a shot some time over the weekend. Haven't heard of a 30-30-30 reset, will look that up.
I haven't checked recently on prices of used RBS units but I seem to recall seeing them before and being surprised that they were almost as much as I paid new, but I guess new ones are probably no longer available now. If it came to replacement, are the Orbi 50 series still a good buy or is the cost/benefit ratio likely to make a newer system worth considering?
Sep 27, 2024Guru - Experienced User
Thought a good system, no longer supported by NG.
I'd take a look at a 750 or 850 or maybe 960 series in your future.
