hcarts_harold's avatar
Aug 16, 2018
RBS50 Satellite functions but does not appear under "Connected Satellites"
As is shown in the attached screenshot, my two RBS50 satellites show up under "Connected Devices" in the RBR50 admin area, however they do not appear under "Connected Satellites" as expected.  Should...
  • FURRYe38's avatar
    Aug 16, 2018
    What FW is currently loaded?
    What is the Mfr and model# of the IP modem the Orbi is connected too?
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    If you reboot the satellites first then the router do they appear in the connected satellites section?
    Try a different browser like IE11 or FF or Opera?
