hcarts_harold
Aug 16, 2018Aspirant
RBS50 Satellite functions but does not appear under "Connected Satellites"
As is shown in the attached screenshot, my two RBS50 satellites show up under "Connected Devices" in the RBR50 admin area, however they do not appear under "Connected Satellites" as expected. Should...
- Aug 16, 2018
What FW is currently loaded?
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.If you reboot the satellites first then the router do they appear in the connected satellites section?
Try a different browser like IE11 or FF or Opera?
Aug 16, 2018Guru - Experienced User
Whats this art building material made up of if you know?
hcarts_harold wrote:
All devices are using firmware 2.1.4.16
Modem is a Cisco DPC3008
Satellites are on separate floors, probably about 30 feet.
Square feet: 5000+ (A large arts building)
Tomorrow I will try your suggestions about rebooting and using a different browser.
Thank you.
hcarts_harold
The building is pretty old. Who knows what is in the walls.
I will say this: initially the Satellites were listed properly under "connected Satellites" and the "Backhaul status" was listed as "good". That was a few weeks ago.
