ewiesner
Feb 23, 2018Aspirant
RBS50 Satellite goes off line
One of the satellites is located in my bedroom and most every night it wakes me as it progresses through the amber, blue and white light as if it has lost it's connection or has been recycled. I'm n...
Retired_Member
Feb 23, 20182.1.2.18 has reported problems. You may want to step back to 2.0.1.14
I called Netgear customer support and they walked me through the process. Took about 20 minutes. You can also do it yourself. Not hard.
ewiesner
I see version 2.0.1.4, I do not see version 2.0.1.14.... is this a mistake?
- webminsterFeb 23, 2018Luminary
Typo. He meant 2.0.1.4.
- ewiesnerFeb 23, 2018Aspirant
OK, so I want to rollback my firmware, but I am unable to login to my satellite devices. I can successfully login to orbilogon.com, but cannot get my logon to be accepted by the satellite. Suggestions?
- FURRYe38Feb 23, 2018Guru - Experienced User
Does admin and password work?
The log in of the Satellite should be the same as the Orbi Router...
