0703kb
May 02, 2020Star
RBS50 satellite keeps dropping a wired device (Fingbox) but other RBS50 satellite does not.
I bought RBR50 and RBS50 pack and the later on, purchased an additional RBS50. All working fine. I also have a "fingbox" for managing access to the network. It is wired into a satellite. The problem ...
May 02, 2020Guru - Experienced User
Try connecting the box to the RBR..
