richvolpe
Apr 16, 2021Aspirant
RBS50 Satellite not connecting
My Orbi RBS50 satellite has been working perfectly for 2 years, and then suddenly stopped. It is not visible as a connected device on the main router (even when hard-wired directly to the router). ...
vajim
Apr 16, 2021Master
richvolpe wrote:My Orbi RBS50 satellite has been working perfectly for 2 years, and then suddenly stopped. It is not visible as a connected device on the main router (even when hard-wired directly to the router).
The green power light at the back of the satellite turns on, but the top ring LED does not.
I have tried resetting the satellite, but regardless of how long I hold the reset button, nothing happens (i.e. no change of the power light to amber). Does this alone mean the device is fried??
Assuming not fried, I have a feeling it had something originally to do with a firmware update that may have got updated on the router, but not the satellite (i.e. they are on different firmwares). I would like to try manually update the satellite firmware, but can't work out how to do so without the device being visible on the router.
Any assistance/ideas would be greatly welcomed!!!
how do you know it's not working? what are you use to check the connection? the app? if so, use the pc login. You may have to reboot all, modem, router and sat. yes the firmware you mention can be a problem. how did that happen? in that case you may need to do a factory reset.
richvolpe
I was browsing to 192.168.1.1 from my pc and clicking attached devices and no satellite device is showing.
I did try reboot both router and satellite multiple times.
How do I go about factory reset of the satellite? Holding down the reset button appears to have no effect regardless of how long I hold it.
- vajimApr 16, 2021Master
How do I go about factory reset of the satellite? Holding down the reset button appears to have no effect regardless of how long I hold it.I'd still hold off. That attached listing in the pc login was acting up for me awhile back. Not showing sats and devices. I just left it alone and a few days later all was well.
What devices do you think should be connected to that sat? Do they work? Can you hardwire a device to that sat?
