DK986's avatar
DK986
RBS50 SATELLITE NOT RESPONSIVE
First off, I'm not a technically minded user - just a sole trader working from home with a need for a stable network.   I have a Orbis RBR50 Router with two satellites which are operating well with...
  • DK986's avatar
    DK986
    Feb 09, 2023
    All
    Thanks for your help and suggestions!
    I've been able to solve the problem with the help of a local Netgear accredited supplier and the issue related to corrupt firmware on the satellite in question. The power light blinked green upon startup then flashed red after approximately 15 seconds and continued to do so with the LED flashing white throughout.
    The issue was that the firmware could not update wirelessly and so had to be hard wired and firmware updated in sequence: According to my supplier he had to TFTP to the unit, then apply the following firmware levels in sequence:-
    • 2.7.2.104
    • 2.7.3.22
    • 2.7.4.24
    Taking the unit directly to 2.7.4.24 failed
    It is now working and re-connected to my network. Thanks to all DK986
