djweiler's avatar
Jun 10, 2018
RBS50 satellite random reboots
AC3000 system (RBR50 router and two RBS50 satellites) purchased at Costco in June-2017.
One of the satellites (always the same one) randomly reboots several times per day for no apparent reason.
V2.1.4.10 firmware.
Apple macOS high sierra version 10.13.4
2-story home.  3500 sq ft.
Arris Surfboard SB6190 cable modem and Orbi router on 2nd floor.  The two satellites on 1st floor.  SRS configuration (satellites at opposite ends of 1st floor and router located between satellites on 2nd floor).
For such an expensive system ($500), it has been very troublesome.  The router had to be replaced twice in Oct-2017.  Now this satellite issue started two weeks ago.  Disconnecting power from satellite and rebooting has not helped.
Not a happy customer.
  • Have not noticed any disconnects since I moved the satellite closer to the router a week ago.
    • djweiler's avatar
      djweiler
      Tutor
      40' from router to satellite that has random reboots.
      36' from router to satellite that is working fine.
      Using Auto for 2.4Ghz.
      Channel 48 for 5Ghz
      7 wifi neighbors
      • FURRYe38's avatar
        Try using one of the manual channels mentioned.
        The signal level maybe on the fringes at 40 feet, depending upon building materials as well.
        I would keep the 36feet and see how it goes there...
        Channel 48 for 5Ghz
        7 wifi neighbors
