oldgreysubs
Dec 22, 2021Tutor
RBS50 satellite replacement
I have an RBR50 and RBS50 system and wish to extend the mesh coverage but RBS50s are no longer available. Whic new model satellite will work with my existing setup please?
- Dec 22, 2021
Netgear has set up a community forum specifically for the Orbi AC products. Most of the people who watch that forum are more likely to have experience with Orbi and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
Dec 22, 2021Guru - Experienced User
compatible with your system?
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
- oldgreysubsDec 22, 2021Tutor
Thanks some good options there. Will see whats available on line.....cheers!
- FURRYe38Dec 22, 2021Guru - Experienced User
Thank you.
