Shiuf
Oct 11, 2018Aspirant
RBS50 satellite will not reset, does not connect.
My satellite stopped working today. Running 2.1.4.16. Router works fine, on 2.2.1.210. The satellite does not connect to the router even if I'm 5 feet away. I tried a reset with a paperclip in the bac...
Oct 11, 2018Guru - Experienced User
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
Are you holding in the pin button until the top led turn on AMBER? Then let go. The led will then start to blink WHITE then plusate WHITE...
https://community.netgear.com/t5/Orbi/RBS40-firmware-V2-2-1-210-failed-what-next/m-p/1650247#M43189
- ShiufOct 11, 2018AspirantYes I've held it down for as long as 30 seconds. There are no changes in anything. The top ring doesn't light up at all during the whole process, the little led on the back next to the power button stays green
- ShiufOct 11, 2018AspirantAlso, I can't do the manual update like that link suggests, the satellite does not connect to the router. Unless I can plug the satellite directly into the computer to update, but it doesn't sound like that's an option
- FURRYe38Oct 11, 2018Guru - Experienced User
I would contact NG support and ask for help and information on this. The top LED is supposed to turn on AMBER when holding the pin button.
- Christian_ROct 12, 2018NETGEAR Employee Retired
Hello Shiuf - Please contact support and they will initiate a replacement if deemed necessary.
https://www.netgear.com/support/
~Christian
