Shiuf
Oct 11, 2018Aspirant
RBS50 satellite will not reset, does not connect.
My satellite stopped working today. Running 2.1.4.16. Router works fine, on 2.2.1.210. The satellite does not connect to the router even if I'm 5 feet away. I tried a reset with a paperclip in the bac...
Shiuf
Yes I've held it down for as long as 30 seconds. There are no changes in anything. The top ring doesn't light up at all during the whole process, the little led on the back next to the power button stays green
Shiuf
Also, I can't do the manual update like that link suggests, the satellite does not connect to the router. Unless I can plug the satellite directly into the computer to update, but it doesn't sound like that's an option
