Boppy
May 19, 2022Aspirant
RBS50 satellite will not update V2.7.4.24
I was able to manually update the RBR50 router but not the RBS50 satellite. The message: This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware...
- May 19, 2022
The Attached Devices page shows the IP address of each satellite.
In the web browser, enter that URL (e.g. http://192.168.1.5)*. Enter the web password. Firmware Update is the bottom menu item.
* If I had 'planned ahead', I would have left IP's 2,3,4,5 for satellites, but I was so intent on installing the Orbi that I connected two PC's and a printer before activating the satellite, which then got IP #5.
Boppy
Thanks for the quick reply, but I did use the RBS50 img file and downloaded it twice in case it was corrupted.
I see a new post that says do RBS50 before RBR50. I tried the automatic option three times and then tried the manual. RBS50 failed but RBR50 worked.
Where do I go from here? Do I need to do a factory reset?
CrimpOn
May 19, 2022Guru - Experienced User
A factory reset on satellites is totally painless. (They have nothing to configure.) Can't hurt.
It is not clear to me whether you are using the router's Firmware Update menu, Manual Update tab or are connecting directly to the satellite's web page.
- BoppyMay 19, 2022Aspirant
When I first logged on, there was a note about new firmware. I clicked that. After a couple of tries with the automatic, I tried the manual option. I have not tried the sat's web page. How do I access that?
- CrimpOnMay 19, 2022Guru - Experienced User
Thanks for your help! I went to the sat page and it updated easily.
I also love my Orbis -- I have 3.
