Boppy
May 19, 2022Aspirant
RBS50 satellite will not update V2.7.4.24
I was able to manually update the RBR50 router but not the RBS50 satellite. The message: This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware...
- May 19, 2022
The Attached Devices page shows the IP address of each satellite.
In the web browser, enter that URL (e.g. http://192.168.1.5)*. Enter the web password. Firmware Update is the bottom menu item.
* If I had 'planned ahead', I would have left IP's 2,3,4,5 for satellites, but I was so intent on installing the Orbi that I connected two PC's and a printer before activating the satellite, which then got IP #5.
Boppy
When I first logged on, there was a note about new firmware. I clicked that. After a couple of tries with the automatic, I tried the manual option. I have not tried the sat's web page. How do I access that?
CrimpOn
May 19, 2022Guru - Experienced User
- BoppyMay 19, 2022Aspirant
Thanks for your help! I went to the sat page and it updated easily.
I also love my Orbis -- I have 3.
- FURRYe38May 19, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
