Orbi1Fan's avatar
Orbi1Fan
RBS50 Satellite Won't Boot
Hi folks, hoping someone can point me in the right direction.
I have a mesh system that's been working fine for about 15 months, (RBR50 + 2 satellites).
I powered off one of the satellites yesterday to re-route the power cable ... not it won't boot.
Green power light comes on, but nothing else, (no LED ring), tried the reset switch (multiple various ways, reset then turn on power, power first then reset, etc.) ... no change.   Any ideas how to kick this thing into life ... are there any "tricks" out ?
Rotuer and other satellite just fine ... so it's just this one that won't start.
Thank you in advance.
  • FURRYe38's avatar
    Maybe a faulty or bad RBS. Not much else can be done with it. Would need to be replaced. Contact NG support to see what your options are.
    Good Luck.
