pbarham's avatar
pbarham
Apprentice
Dec 23, 2020
RBS50 Satellite Won't sync - even in same room
Hi,   Had to reinstall and reimage the firmware on my router recently after a power brownout.   The router now seems to be working just fine, but I am unable to get my satellite to sync.    When...
  • pbarham's avatar
    Dec 23, 2020
    Update:  Managed to get the satellite back online by connecting it directly to the router with a cat5 cable.  The status changed to 'syncing config' and then it picked up the correct SSID and admin password.
    Not sure why it couldn't sync over the wireless?
