KristieSwisher
Feb 21, 2018Aspirant
RBS50 Satellites (2) WILL NOT update automatically or manually
I have an ORBI RBR50 with 2 RBS50 satellites. The router has been automatically updated to firmware version V2.1.2.18, but the satellites WILL NOT automatically update so I have REPEATEDLY tried to u...
Feb 22, 2018Guru - Experienced User
What browser are you using? Try IE11 or FF browsers when updating FW. Seen bad issues with Chrome.
Are you connecting directly to the Satellite with a LAN wired PC and to it's Web Page?
Verify the current version thats loaded on the Satellites first before updating FW.
Current version for RBS50 units is v2.0.1.4:
- KristieSwisherFeb 22, 2018Aspirant
Hi--Thank You for your response. In my previous attempts to update the firmware, I was using Chrome, but tried again with Firefox to have the same results. I am not connecting directly to the satellite with a LAN wired PC--Orbi is wire connected to PC, but both satellites are connected wirelessly and on different floors of my house. I have tried updating from the LAN wired PC where Orbi is though with both browsers, and it has not made a difference in the results. It is odd, but when trying to update automatically, satellites one and two will first give the message to "Please wait"...and then satellite one will switch to "service unreachable" and satellite two will switch to "No internet" which is not correct as both satellites have active items connected to them at the time, which is puzzling to me as to why I would even get that "No internet" message. I have verified both satellites have firmware version V2.0.0.74. I did attempt to download FW V2.0.1.4 manually on FF, and when I got the authenticate/sign-in message, my password was not accepted, even though it was the same log-in just used to access my network! This same thing has happened on Chrome too.
- FURRYe38Feb 23, 2018Guru - Experienced User
Please try connecting to the Satellites using a wired LAN cable PC or laptop. Thats how I got mine updated. Possible that updating thru the router is not working right...
- KristieSwisherFeb 24, 2018Aspirant
Hi--I don'tthink that I have anymore cables to hook-up the satellites directly to the router and wired PC. I will have to check and then work on this situation more next week when I can get more time. This whole situation is puzzling to me as I never had any previous problems with the ORBI system installation or previous updates, which all worked as they should, both auto and manually. Thank you for your help.
