staeren
Mar 18, 2022Follower
RBS50 satellites compatibility?
is there anyone who can tell me with which ORBI mesh wifi systems the RBS50 sat are compatible?
Mar 18, 2022Guru - Experienced User
You can use the RBS50 satellites with the RBR20, RBR40, RBR50.
Supposedly you can hardwired it into the AX systems but it doesn't integrate
