novice24Bris
Jan 19, 2024Tutor
RBS50 setup failing when connecting router to the internet
I recently got hold of a used RBS50 router and satellite. I've manage to set the router up so far as it's connecting to the modem and my phone will then connect to the network. It checks the cables, ...
- Jan 22, 2024
Just to close the loop on this - I managed to find a previously unknown BT username for the router (no password) when I dug into the Network Connection settings on my laptop, and use this in the PPoE settings for the RBR50. It did the job and 'tricked' the BT modem into thinking the Orbi was a BT router. WiFi now working well throughout the house and satellite is also operational.
Thanks for the support.
Jan 19, 2024Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Is there any specific ISP configurations needed? Check with the ISP about this.
novice24Bris
Jan 19, 2024Tutor
Thanks for replying. Apologies, I do have a RBR50 acting as the router.
The modem was installed by BT (UK provider) around 3 years ago. No distinguishable markings, per the attached picture.
I have tried that reset sequence a few times but no luck. The ISP won't give me any additional details re. configurations as they say they do not want to be liable for any changes and negative effects.
And the cables appear to be fine as my old router works fine when connected to the modem.
