gaingolfer
Aug 27, 2020Aspirant
RBS50 show false "not connected" on PC app but not on Android mobile app
My Orbi base unit RBR50 shows the satellite as DISCONNECTED. Only device hard wired to it is a ROKU box. The Roku works! However, when I login to the admin portal on my Android phone, the Satellit...
- Aug 27, 2020
It turns out that the Satellite needed a firmware update but that message didn't show up when I first logged into the admin portal on my PC. However, when I logged in on my phone the Satellite was “ connected” but with an update message. I did the update and all is OK now.
Thank you for your reply!
CrimpOn
Aug 27, 2020Guru - Experienced User
gaingolfer wrote:My Orbi base unit RBR50 shows the satellite as DISCONNECTED. Only device hard wired to it is a ROKU box. The Roku works!
However, when I login to the admin portal on my Android phone, the Satellite shows "Connected". It's obviously Connected because I can watch programs via my Roku.
What is the firmware version on the Orbi router and satellite? Connection status is one area where people report "strange things" from some firmware releases.
gaingolfer
