nw-net's avatar
nw-net
RBS50 showing as disconnected
A few days ago my 2 yo RBK53 setup (1 RBR50 + 2 RBS50) had a major hiccup! A reboot of the RBR50 and one RBS50 seemed to have restored connectivity. However, on the Orbilogin website's Attached Devic...
  • FURRYe38's avatar
    Aug 29, 2021
    Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
    Is Daisy Chain enabled or disabled on the RBR?
    Swap arouond RBS with each other to see if problem follows.
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
