Retired_Member
Mar 13, 2018RBS50 Showing in circle
Hi, the circle app that I have installed shows my Orbi RBS50 as a device, is this correct?
- Retired_MemberMar 20, 2018
I seem to be having trouble with my Orbi again. The circle app showing a netgear device again, which I believe is the RBS50. How do I have RBS50 dissapear within the circle app.
- StarbuckyApprentice
My RBS50 also shows up in the Circle app. I have it configed as "unmanaged".
- Retired_Member
Emm, why unmanaged may I ask. I not sure what unmanaged is for?
You don't want devices which process/route traffic from other devices to be managed by Circle. Ideally only end-points/devices which are used to access content on the internet. The Circle support site also explains it.
You could possibly add it as a "Home" device but it wouldn't be filtered anyway. I'd leave it alone seeing how there are other potential issues with Orbi systems at the moement.
