aebrahim
Jan 08, 2020Aspirant
RBS50 v1 stuck at 2.5.0.38, can't upgrade to 2.5.1.8
My home wifi network contains the following: RBR50 v1 at 2.5.1.8 RBS50 v1 at 2.5.0.38 RBS50 v2 at 2.5.1.8 Try as I might I can't get the RBS50 v1 to upgrade to 2.5.1.8. I've tried manual firmw...
Jan 08, 2020Guru - Experienced User
Try this, factory reset the 1 RBS and connect a wired PC to the back of the RBS that has the v2.5.1.8 file on it. Don't sync the RBS. Wait about 5 minutes and you should be able to use a web broswer like IE11 or Firefox and log into the RBSs web page at 192.168.1.250. Log in will be admin and PW is password. Use the RBSs web page to send the FW update file. The file should take.
Disconect from the RBS and reconnect to the RBR, you might remove the RBS from the RBRs connected clients page, then go for re-sync
aebrahim
Jan 09, 2020Aspirant
This didn't work. I'm still stuck at 2.5.0.38
I tried to hard reset my satellite by holding down reset until the orange lights on power/LED started to flash but this didn't work. When I reset the router it had un-synced but still had my old settings intact and I had to log into the router interface on 192.168.1.250 using my old password.
How can I force it to reset so that it really forgets everything?
I tried to update using TFTP but I wasn't successful, though I might have been doing that wrong.
Any ideas please?
