Tarheel98
Feb 07, 2020Aspirant
RBS50 warranty replacement FW upgrade
I have a RBR50 with two RBS50 satellites with FW v2.5.1.8. I just received a warranty replacement for one of the satellites and it came with v2.1.4.16. I am trying to upgrade the FW manually because ...
Tarheel98
Feb 08, 2020Aspirant
Thank you, tomschmidt. I appreciate you taking the time to respond. I followed your instructions (same steps as in previous tries). Satellite is plugge in. I can log into it on my network. I dowloaded and extracted the RBS50 file. The upload to the satellite appears to reach 100% every time but the IMG file is rejected. I did this now on a Mac and a Win10 PC both over Ethernet and WIFI. No dice. Rejected in all attempts. It says it is the wrong file.
tomschmidt
Feb 08, 2020Virtuoso
Tarheel98, I suggest you contact Netgear and have them troubleshoot the issue. You may have received a defective warranty replacement if it will not allow firmware updates.
- Tarheel98Feb 08, 2020Aspirant
Will do, tomschmidt . Thanks again for your time!
