Tarheel98
Feb 07, 2020Aspirant
RBS50 warranty replacement FW upgrade
I have a RBR50 with two RBS50 satellites with FW v2.5.1.8. I just received a warranty replacement for one of the satellites and it came with v2.1.4.16. I am trying to upgrade the FW manually because ...
Tarheel98
Feb 08, 2020Aspirant
FURRYe38Thank you for your assistance. Unfortunately, this did not work either. I have now tried to load all four FW versions that were mentioned in this thread both over Ethernet and WIFI. The result is the same every time. The error message states that the FW file is incorrect.
Jetdrive
Feb 08, 2020Luminary
Just guessing here but you might try a reset to default settings on the router and then try again?
