MarcusTan93
Feb 03, 2021Tutor
RBS50 WiFi No internet
Hi, I have a RBK50 System (RBR50 +RBS50) I am having issues with RBS50 Internet Connection. 1. RBR50(Router) has no issue connecting to the internet. Both on Wifi and Ethernet 2. RBS50(Satelit...
- Feb 03, 2021
Oh well. I just factory reset the RBS50 sat and resync the sat to the router. Magically it works now...finger crossed this issue won't happen again. Thx for your input anyways vajim
vajim
Feb 03, 2021Master
MarcusTan93 wrote:Hi,
2. RBS50(Satelite) is linked with Ethernet Backhaul.
3. My PC connecting to RBS50 via Ethernet has no issues connecting to Internet
4. My devices have issues connecting to internet when connecting via RBS50(Satelite)
5. My devices have no issues connecting to internet when connecting via RBR50(Router)
6. RBS50(Satelite) firmware is RBS50-V2.7.2.104
Should you require more information to diagnose , do ask along :)
how do know which of your devices are attempting to connect via the sat?
- MarcusTan93Feb 03, 2021Tutor
Hi Vajim,
1. By going to the attached devices section(via router and satelite admin page)
2. By signal strength. If it is connected to the router, it will at most has 1-2 bars max(My router is quite a distance away and it is at lower floor). If it is connected to satelite, it will be full bar.
- vajimFeb 03, 2021Master
MarcusTan93 wrote:Hi Vajim,
That's what I thought.
Are any of your devices hard wired into the sat?
FYI....just checked my pc login and it says both of my sats disconnected, yet in the devices lists it shows several connected via one of the sats.
Sometimes a simple reboot makes all happy
1. My PC is hardwired via the sat and has no issues connecting to internet.
2. Yes. Orbi PC login sometimes false display sat as disconnected(especially from the phone app).
3. It was on an older firmware so i updated it and rebooted also still same issue.
