MarcusTan93
Feb 03, 2021Tutor
RBS50 WiFi No internet
Hi, I have a RBK50 System (RBR50 +RBS50) I am having issues with RBS50 Internet Connection. 1. RBR50(Router) has no issue connecting to the internet. Both on Wifi and Ethernet 2. RBS50(Satelit...
- Feb 03, 2021
Oh well. I just factory reset the RBS50 sat and resync the sat to the router. Magically it works now...finger crossed this issue won't happen again. Thx for your input anyways vajim
MarcusTan93
Feb 03, 2021Tutor
Hi Vajim,
1. By going to the attached devices section(via router and satelite admin page)
2. By signal strength. If it is connected to the router, it will at most has 1-2 bars max(My router is quite a distance away and it is at lower floor). If it is connected to satelite, it will be full bar.
vajim
Feb 03, 2021Master
MarcusTan93 wrote:Hi Vajim,
That's what I thought.
Are any of your devices hard wired into the sat?
FYI....just checked my pc login and it says both of my sats disconnected, yet in the devices lists it shows several connected via one of the sats.
Sometimes a simple reboot makes all happy
- MarcusTan93Feb 03, 2021Tutor
1. My PC is hardwired via the sat and has no issues connecting to internet.
2. Yes. Orbi PC login sometimes false display sat as disconnected(especially from the phone app).
3. It was on an older firmware so i updated it and rebooted also still same issue.- vajimFeb 03, 2021Master
3. It was on an older firmware so i updated it and rebooted also still same issue.so....your PC is hardwired via the sat and has no issues connecting to internet......does that mean it really is going through the sat and there is no problem and the pc login is lying..??
Apparently so...I have no issue of connecting to internet via ethernet directly to the sat as the sat is connected to the main router. But when i try to access PC login via my phone, it somehow connects to the sat login page instead(using router address), does that means any issue?
