gman737
Feb 07, 2020Aspirant
RBS50 wifi problem
Model: RBR50, RBS50, RBW30
Firmware: 2.5.0.38
I'm having trouble with the wifi on just the RBS50 satellite. Often when my phone or ipad is connected to this satellite, it shows full strength and connected, but there is no internet and the Orbi app doesn't show a connection. If I reset the wifi on my phone/ipad and move closer to either the RBR50 or RBW30 to force it to connect to one of those, it works fine. The wired connections on the RBS50 also work fine. I tried rebooting everything, and did a factory reset, but no help. It seems like a hardware problem on the satellite, but when I tried to get warranty service, Netgear gave me the runaround and either tried to charge me a bunch for tech support or said the equipment is working properly.
My next idea is to buy a used RBS50 on ebay, but before I spend more money, I wanted to see if anyone had other ideas. Also, if I could just disable wifi on the RBS50 (which doesn't seem possible), the other units provide enough coverage for the house, but I really need the wired part of the RBS50.
I might have solved the mystery, time will tell. I had malfunctioning wifi-to-ethernet bridge that wanted to act as a DNS server for the network. I replaced the adapter and devices are connecting to the RBS50 normally now. Thanks for all the help and advice.
I do not have a solution, but my guess is that everyone will suggest to upgrade the firmware to 2.5.1.8. The firmware 2.3.0.38 had problems and was taken back by Netgear. That would be the first thing I try. (Upgrade the whole system, satellites first.)
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Try updating to v2.5.1.8...
- gman737Aspirant
Ok thanks for the tips. I will try updating firmware first.
Here is some of the requested info:
ISP Modem: Comcast Xfinity Motorola SB6121. I get 80-90Mbps normally.
Home: ~3000 sq ft, 3 story
RBR & RBS are on the same floor about 25-30ft apart. Again, the wired connections on the RBS work flawlessly at full speed. The RBW30 is on another floor at the other end of the house and it works fine too.
I ran a network analysis to find the best channel for 2.4ghz. Channel 11 seems the least congested (pretty busy neighborhood).
For 5ghz, I was on channel 40. It looked like everyone else was on the same so I changed to 48. But my wifi analyzer shows it stuck on channel 42 which isn't an option so not sure what's going on there.
The more advanced options I will try if the firmware doesn't work. Thanks again.
Try the system with out the RBWs.
Try the FW update as well.
