b-evilsizor
Nov 23, 2020Aspirant
RBS50 will not reset
Purchased a RBR50 with RBS50 satellite package and initially loved it and raved about it! Unfortunately that is no longer the case. The main router still works fairly decent but no longer have the co...
Nov 23, 2020Guru - Experienced User
Sp pressing the reset button for 15 seconds then release, does the top ring LED start to blink WHITE then pulsate WHITE?
b-evilsizor
Top led doesn't even light up
- FURRYe38Nov 23, 2020Guru - Experienced User
Try a different power adapter, one from the RBR if you can test that quickly or from anther RBS if you have one. If this doesn't work, then I would presume the RBS is bad and needs to be replace.
- b-evilsizorNov 23, 2020AspirantSlightly embarrassed i didn't think to swap power supplies prior, but unfortunately still all the same symptoms on the remote satellite
:smileysad:
