b-evilsizor
Nov 23, 2020Aspirant
RBS50 will not reset
Purchased a RBR50 with RBS50 satellite package and initially loved it and raved about it! Unfortunately that is no longer the case. The main router still works fairly decent but no longer have the co...
b-evilsizor
Top led doesn't even light up
Nov 23, 2020Guru - Experienced User
Try a different power adapter, one from the RBR if you can test that quickly or from anther RBS if you have one. If this doesn't work, then I would presume the RBS is bad and needs to be replace.
- b-evilsizorNov 23, 2020AspirantSlightly embarrassed i didn't think to swap power supplies prior, but unfortunately still all the same symptoms on the remote satellite
- FURRYe38Nov 23, 2020Guru - Experienced User
:smileysad:
- b-evilsizorNov 23, 2020AspirantUgh.. not the response I was hoping for.. any recommendations on a new and comparable setup that might last beyond this paperweight?
