ileodo
Jan 05, 2020Tutor
RBS50 wired backhaul shown as 5G/2.4G in AP Mode
Here is my setup: Internet ---WAN---> X4S R7800 (Router/Gateway)-- LAN#1 -> RBR50 LAN#1 (AP mode) | ...
CrimpOn
Jan 05, 2020Guru - Experienced User
Have you tried connecting the RBS50 to one of the LAN ports on the RBR50, rather than to the R7800?
ileodo
Jan 05, 2020Tutor
it would be very difficult to test that in my case. (realy hard to move the RBS). but why that matters?
CrimpOn wrote:Have you tried connecting the RBS50 to one of the LAN ports on the RBR50, rather than to the R7800?
- CrimpOnJan 05, 2020Guru - Experienced User
Well, sorry. My Orbi WiFi is located right next to my modem, so I just assumed that your Orbi was right next to the R7800 and that it would be a simple matter of moving the cable. So, those "LANs" are switches located in different areas away from the R7800?
- ileodoJan 05, 2020Tutor
Thanks, actaully yes. the router, RBS and RBR are in three different rooms.
Well, then "I got nothin." You might want to browse some of the posts about firmware 2.5.1.8. When I saw the chorus of complaints, I decided to "wait and see". There might be something about ethernet backhaul in those posts.
(a long time ago) it was recommended to do an ethernet sync with the satellite directly connected to the router with a patch cable before relocating it to the final destination. That would be an easy test. i.e. move it. Let it connect via WiFi backhaul. Then, plug in a patch cable and verify that it changes from WiFi to "wired" backhaul. Finally, move it back. (If you already did this, I have struck out again.)
