saurin13's avatar
Aug 06, 2019
RBS50 wired backhaul stopped working
I have two satellite RBR50s and both are connected to a wired backhaul. Both were working until recently (both are on the most recent firmware (V2.3.5.30).     Now one of them will only connect to ...
  • saurin13's avatar
    saurin13
    Aug 08, 2019
    Thanks for the quick response! It is connected directly to a MOCA extender.
    I did get it to work eventually. I turned it off, unplugged all Ethernet wires, turned it back on. After it connected to the Wi-Fi backhual after about 15 min, I connected the wired backhaul wire. It worked then.
