saurin13
Aug 06, 2019Tutor
RBS50 wired backhaul stopped working
I have two satellite RBR50s and both are connected to a wired backhaul. Both were working until recently (both are on the most recent firmware (V2.3.5.30). Now one of them will only connect to ...
- Aug 08, 2019Thanks for the quick response! It is connected directly to a MOCA extender.
I did get it to work eventually. I turned it off, unplugged all Ethernet wires, turned it back on. After it connected to the Wi-Fi backhual after about 15 min, I connected the wired backhaul wire. It worked then.
Aug 21, 2019Guru - Experienced User
When the RBS is connected va ethernet, then the RBS doesn't use it's wireless backhaul. That goes thru the cable wire. When the RBS is wireless and Daisy Chained, then the back wireless backhaul is used to conect to the other RBS in the chain.
