md12345
Mar 24, 2020Follower
RBS50 won't allow admin password reset HELP
All of a sudden my app will not allow me to login. Says my admin password is not correct. Nothing was changed. I go thru the "forgot password" to try to recover the password and it tells me "the i...
CrimpOn
Mar 30, 2020Guru - Experienced User
For issues with the Orbi "app", the forum devoted to the app is probably more likely to produce results:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
If the Orbi web interface also rejects the password which you believe to be correct, the only recourse is to perform a "Factory Reset"
