claudermilk
Mar 30, 2024Aspirant
RBS50 Wont connect to RBR50 after power outage
I had a brief power outage and after getting power restored the RBS50 satellite won't connect to the RBR50 router. In the past this hasn't been a problem, power cycle things in order and it automagic...
CrimpOn
Mar 30, 2024Guru - Experienced User
The RBR50 User Manual describes the satellite ring LED states:
Assuming that the satellite is not connected to the router with Ethernet, I also like to temporarily relocate the satellite to be close to the router in order to make it more convenient to observe what is going on.
It might be worth performing a Factory Reset on the satellite. (holding an object in that tiny 'Reset' hole until the power LED turns amber and begins to blink. Then release.) No need to touch any sync buttons. If the ring LED continues to flash white for more than 2 minutes, there is definitely a problem.
- claudermilkMar 31, 2024Aspirant
I had moved it to sit right next to the router and it was stuck at the pulsing white LED for a long time. I left it alone (after giving up) for the day and visited family. Getting up in the morning I saw no light on either unit. I checked on the router's web interface and it actually showed the satellite as connected! I've moved it back to its normal location and am powering it up now. I expected another extended boot and link session, but while typing the above, it has connected back to the router as it usually does. It seems all is good now, though I have no idea why that power outage threw the satellite for such a loop this time.
I guess patience is the key.
- FURRYe38Apr 01, 2024Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.What FW version is on the RBR and RBS?
FW version same version on the RBS as whats on the RBR?
What channel configurations are currently set on the router?
