dhsudbury
Jun 03, 2020Follower
RBS50 won't sync/ can't ping
Hi - A few days ago I noticed my RBS50 was no longer sync'd with the RBR50 (wired backhaul) - just a constant pulsing white light. I've tried most (if not all) of the tricks I've read here with...
Jun 04, 2020Guru - Experienced User
If pressing the reset button on the back of the RBS for 15 seconds then release and connecting 1 LAN connected PC to the back of the RBB, setting the PC at an IP address automatically from the RBS and using a web browser to connect to the RBSs web page at 192.168.1.250 doesn't access it's web page, seems the RBS is bad.
