TeKK1e
Jun 10, 2020Aspirant
RBS50 Won't Sync
Greeting. My RBK50 got firmware auto updated via Orbi app yesterday, RBS50 satellite was not updated. In web gui after the update, the satellite was listed as disconnected. I've read plenty of threads here and after all the syncing attempts via hardware, app and web gui, factory reset, nothing worked. I used tfpt and uploaded the latest rbs50 sofwater x. 16, same version as the router. And it still won't sync.
My RBS50 behaves like everything is normal. It boots up. Power LED solid green. Top ring LED begins flashing white then after some seconds goes into pulsating white, which stays for a min or two and then no light at all. Pressing the sync button has no reaction what so ever.
Netgear has offered to have a chat with me for $89. That's nice of them, especially since their auto update feature in the app caused this issue in the first place by updating RBK50 first... I'm out of 90 day warranty as bought renewed set 5 months ago.
What are my options? Please help. Thank you.
Factory reset the RBR and RBS and setup from scratch.
- TeKK1eAspirantThank you. I didn't want to disconnect my entire house from the network. But let me try.
- TeKK1eAspirantSo I factory reset RBK and RBS, and tried setting up as new connection. It was not able to sync satellite after numerous tries. So no go. It said 0 out of 1 satellite found.
One thing I've noticed when factory resetting the RBS satellite, holding the pin until power LED flashes amber a few times, I let go, and the power LED just goes off, it does not turn green. So it's not initializing? It goes back on when I power cycle it.
