Silkysully
Dec 01, 2018Aspirant
RBS50
Our IT guy installed our Orbi RBK53 system and placed the 2 RBS50 satellite units. UI was not here when he installed it. I cannot find where he put one of the satellite units. Is there a way to ph...
ekhalil
Dec 01, 2018Master
Switch off the Router (RBR unit) so the ring on the Satellite will light magenta. Switch off the lights at home so you can find the magenta light and the “missing” Satellite. :)
Silkysully
Dec 02, 2018Aspirant
Thanks Virtuoso.
Another stupid question. When I turn the router unit back on, does it automatically resync with the satellite units, or do i have to resync it?
Silkysully
- ekhalilDec 02, 2018Master
Silkysully wrote:
Thanks Virtuoso.
Silkysully
It should resync automatically. Just switch it on and wait couple of minutes for the Satellites to resync with the Router.
- SilkysullyDec 02, 2018Aspirant
Thanks!
