goibear
Oct 09, 2019Aspirant
Rbs50
Burn marks on orbi satelite should i be worried.
- Oct 10, 2019
Ugh. Beats me. Neither my router nor satellite look like that. On the other hand, if it doesn't smell burnt, maybe it isn't.
Just don't place it next to something that will catch fire easily.
goibear
Oct 10, 2019Aspirant
CrimpOn
Oct 10, 2019Guru - Experienced User
- FURRYe38Oct 11, 2019Guru - Experienced User
That would not be cuased by something under or inside the case. That looks like something landed on the top cover or maybe the top cover plastic had some corrupt materials in the mix and has degraded.
Is there any indiation of a burning smell coming from the unit?Is this the only unit that exhibits this?
These marks only on the top cover or on the case as well?
Is the system working ok?
CrimpOn wrote:Ugh. Beats me. Neither my router nor satellite look like that. On the other hand, if it doesn't smell burnt, maybe it isn't.
- goibearOct 11, 2019AspirantNo burning smell still works. Will keep an eye on it thanks everyone.
