D-Rob
Aug 24, 2020Follower
RBS50
I have an ORBI Mesh System ORBI5 with an RBR20 router. Would an Orbi RPS50 be compatiable as a member of my mesh network?
Aug 24, 2020Guru - Experienced User
Yes it will though the higher wireless back haul speed will match 866Mpbs that the RBR20 supports and you will not get 1733Mpbs which the RBS50 supports when connected to RBR50. Thought the RBS50 will work fine.
