D-Rob
Aug 24, 2020Follower
RBS50
I have an ORBI Mesh System ORBI5 with an RBR20 router. Would an Orbi RPS50 be compatiable as a member of my mesh network?
Mstrbig
Aug 25, 2020Master
D-Rob wrote:I have an ORBI Mesh System ORBI5 with an RBR20 router. Would an Orbi RPS50 be compatiable as a member of my mesh network?
Assuming you mean RBS50, yes it will work fine as an addition to your RBR20 router. You won't benefit from some of the extra power the RBS50 has over the RBR20. But you will benefit from the 6 antennas for better wifi coverage, and the extra LAN inputs on the back, for any hardwire devices you need to attach.
