wmsbrg
Jan 19, 2024Follower
RBS50
I found my old RBS50 can I use it as an extender to give coverage to other corners. my main wifi is a verizon wifi router. it seems like there is no way to get into the RBS50 and do anything...
CrimpOn
Jan 19, 2024Guru - Experienced User
Mesh WiFi systems are designed as a package where multiple WiFi devices for a network. The communication between devices is proprietary by brand. i.e the various mesh systems work with each other, but not with devices from a different brand.
The Netgear RBS50 satellite will integrate with any of the original Orbi WiFi5 routers (RBR50, RBR40, RBR20) but not with anything else, and certainly not with a Verizon WiFi router.
Some manufacturers designed their mesh system where all units are identical. Any of them can be the unit connected to the internet and the rest can be connected to that unit to form a WiFi mesh. Netgear designed their mesh WiFi where one unit is the "router" connected to the internet and the others are "satellites" which must be connected to the router.
