Ethernetguy
Feb 25, 2024Follower
RBS50/RBR50 won't detect proven good ethernet cable backhaul
Hi guys and gals. Have a simple RBR50 - RBS50 router/satellite system. Works fine on 5 GHz backhaul. Will not detect ethernet cable for ethernet backhaul. Tested ethernet cable directly into TV and i...
Feb 25, 2024Guru - Experienced User
Make sure the RBS are wirelessly and fully synced first over wireless.
Make sure ethernet connections are as follows:
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System 📡 ‌‌🛰️
Ensure FW is up to date on the RBS and RBR.
Ensure your using good quality LAN cables. CAT6 is recommended.
