MarcoBru
Mar 14, 2020Tutor
RBS50v2 - very poor system
dear ppl let me try here to find some suggestions, because up to now I'm very frustrated how poor are the performances of that kit, and due to the virus situation I've serious issues and I can't sen...
Mar 14, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
For any Circle app problems or information, Please post about this in the Circle app forum:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
You can add other RBS. Extenders may work however would not be using any wireless backhaul as RBS do. Some externders may not work at all.
- MarcoBruMar 14, 2020Tutor
thank you alot
about performances, I did so many trials with the support, that my conclusions are definitive: Poor wireless coverage of the devices, we concluded that airport devices are definetly more powerful as signal strengt.
Btw: latest firmware, problem is not internet but wifi coverage, both satellites are "green" and their connection with server is fine, channels chosen with the support, in any case Im living is a country house, no other networks around
About circle, as discussed with circle support, that is... this tool is not fully compatible with orbi and it is not able to download devices name.
now, coming to answers to my questions
1. ok but ANY satellite can be added to my network or only AC3000? can I add a Ac1200?
2. generic answer: do you know a extender that surely works with orbi?
- FURRYe38Mar 14, 2020Guru - Experienced User
For the size of your home a RBR and just 1 RBS should handle coverage. My 5000sq ft home works well with 1 RBR and 1 RBS.
Building materials maybe a factor.
It's recommended to use only RBS series with Orbi.
One non NG extender I got seem to work ok with Orbi. Though I only had it connected for a short period of time to just update it's FW. You can try to see of it will works off hand if you have one.
Possible that the Orbi system you have could be faulty. Orbi AC wifi is pretty good for coverage.
FURRYe38 wrote:Building materials maybe a factor.
thanx for all
1. Brick walls as everywhere in Italy, but the point is that bricks are same as with the apple airports, more or less positions are well, so we had a clear 1:1 comparison. About faulty device, unfortunately discussion with support team was suspended (delayed) due to the virus situation, it is a option.
2. RBS so also RBS20 shall work? In this case the network will be: RBS50....RBR50...RBS50...RBS20 in daisy chain. Does that affect performances of the other devices on the network?
