ImoHen65
Jul 10, 2020Aspirant
RBS50v2 bricked. Power LED flashing red
Hi, I recently bought a Orbi RBK52 V2 on an auction, basically brand new. On set-up, router and one of the two satellites are working fine. However the second satellite’s power LED is flashing red. Ju...
- Jul 10, 2020
you can try using tftp to recover it.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through of it being done on an extender. should be similar on the satellite.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
a thread of someone who did it on a satellite
Jul 10, 2020Guru - Experienced User
- ImoHen65Jul 10, 2020AspirantThanks for the suggestions! I will try them today. I’ve tried the YouTube extender steps Last night, issue I ran into is I don’t pick up a connection when I connect Ethernet on laptop to the LAN ports on satellite. Not sure why, a red cross symbol reflects below the Ethernet port symbol in the Ethernet network Settings on laptop which doesn’t appear if I connect it to one of the LAN ports on the router as a connection is established there. But will try again and all the the other suggestions you posted.
Thanks.- plemansJul 11, 2020Guru - Experienced UserGood luck!
