RookA
Aug 05, 2021Aspirant
RBS50v2 Causing Packet Loss
Hi all, As of about 2 weeks ago I have been experiencing some packet loss and high ping issues (5+ spikes per minute from 500-3000ms) when connected to my ORBI Satellite. My setup for the l...
Aug 05, 2021Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS?
Try removing any prior satellite connectes seen on the RBRs web page, apply and reboot the RBR then try to re-sync the RBS. Do this while in same room with the RBR and RBS.
Has a factory reset been performed on both RBR and RBS?
