zappe
Jun 10, 2022Aspirant
RBS50v2 firmware update
I'm trying to update the firmware to the latest one, manually. But even though I get no error messages it just stays on the old firmware. Updated RBR50 without issues
- Jun 10, 2022
I typically update satellite firmware by connecting directly to the IP of the satellite (same login credentials as the router).
Then select Firmware Update (bottom menu item).
CrimpOn
Jun 10, 2022Guru - Experienced User
- zappeJun 11, 2022Aspirant
That worked great, thanks!
