BrianJ44
Jan 19, 2025Guide
RBS50v2 not powereing on red light blinking
I have an RBR50 Router, 2 RBS50 Satellites and a third satellite RBS50v2. I just received an update on my Orbi app. It's been a long time in between updates. I upgraded my devices to V2.7.5.6 from V2...
Jan 20, 2025Guru - Experienced User
I'd downgrade the RBR back to last released version of FW. Turn OFF all RBS that were updated.
See if you can get the RBSv2 to connect to the RBR. Then use the RBRs web UI to check for the FW update for the RBSv2 while it's connected. Update ALL should work here.
- BrianJ44Jan 20, 2025Guide
Unfortunately, I am unable to get the RBS50v2 to turn on beyond the red blinking power light. Have tried to reset including a 30-30-30 reset to no avail.
- FURRYe38Jan 22, 2025Guru - Experienced User
Can try the power adapter from the working RBS on this RBS to see if something changes.
If the 30-30-30 didn't fix that, then I guess the RBS is bad. đ
- BrianJ44Jan 24, 2025GuideGood suggestion, unfortunately it didnât work. Is there a way to force the update. I suspect the hardware is corrupted causing the issue
