tiweme
Aug 28, 2023Tutor
RBS50v2 power led flashing red
Hi there, seems there is a problem with the firmware update to 2.7.4.24. I have 1 Router RBK50 and 2 Statellites RBS50. Router and 1 Satellite have been updated correctly, even I was not really a...
- Aug 28, 2023
PROBLEM SOVELD!
I did it along the very good description from shrickus posted 2018-08-13 09:56 PM, but I did it in a Mac environment.
Some observations: mini hub is essential to see that Mac AND satellite are connected. tftp works slightly different - you need three steps:
tftp 192.168.1.1
binary
put <firmware version img file>.
Worked out for me with an RBS50v2 satellite and fw version 2.7.4.24 and gives me trust for the next fw update.
Thanks shrickus
Tilo
tiweme
Aug 28, 2023Tutor
PROBLEM SOVELD!
tftp 192.168.1.1
binary
Thanks shrickus
Tilo
- FURRYe38Aug 28, 2023Guru - Experienced User
If you got the RBS working again. Then you could manually update the RBS then RBR to most current version of FW using the WEB UI on the RBS and RBR:
